R-230 halfshaft mod
For those of you running or planning to run this diff, consider this on the half shafts. It is cheap and goes only on the inboard side. Made of a big washer and a scrap round spacer tacked on the washer, need a little lathe work to fit just right.
http://photos.yahoo.com/bc/mwicard/lst?&.dir=/&.src=ph&.begin=17&.view=t&.order=&.done=http%3a//photos.yahoo.com/bc/mwicard/lst%3f%26.dir=/%26.src=ph%26.view=t
Mark
The R180 is the "baby bear" of the three in both size and strength (the 180 refers to the ring gear diameter). The R200 is the "mama bear". It is a little larger, and a bit stronger. The stubs snap into the sides, vs the bolted on stubs of the R180. Also visually, the R200 has no external bearing carrier plates as does the R180. The mounting hole pattern between the R180 & R200 is the same. The R230 is the "papa bear" with again the larger ring gear. Visually, the R230 is bigger around, but shorter or stubbier (as many of us older members are becoming), and takes a different mounting system than the previous two diff do.
