torque wrench
these look great, and theres little doubt they are a quality tool
1: http://www.emaxaction.com/cdi1503mfrmh.aspx
2: http://www.toolsource.com/torque-wrench-microadj-metal-handle-20150-ftlbs-plain-head-p-95221.html
CONSISTANCY and REPEATABILITY ,rather than exact torque, is the key, if your off a ft lb its not catastrophic.
Ive used both a SEARS and a HOME DEPOT TQ WRENCHs FOR MANY YEARS. built over 150 engines and had zero problems
consistant technique and consistancy in the way you lube and work the torque loads up in stages and having the bolts and studs lubed and cycling, the bolt/stud up to the recomended tq and loosening it and repeating that several times tends t0o give consistant results, USE ARP FASTENERS
http://www.homedepot.com/webapp/wcs/stores/servlet/ProductDisplay?storeId=10051&langId=-1&catalogId=10053&productId=100058237
http://www.sears.com/shc/s/p_10153_12605_00944595000P?vName=Tools&cName=Mechanics+Tools&sName=Torque+Wrenches
btw rod bolts SHOULD have a stretch gauge used but its not 100% mandatory, cycling them up to spec and releasing the tq then repeating several times with a tq wrench, following the APR instructions gets you very consistant results IVE checked the tq wrench results with the stretch gauge
http://store.summitracing.com/partdetail.asp?autofilter=1&part=ARP%2D100%2D9942&N=700+115&autoview=sku
