Window Crank
Rustyfriend
I made a set about 15 years ago. I used the stock hub with the crank and knob cut off. I drilled a hole in the male fitting for the hub and tapped it for a machine screw, 8-32 if memory serves.
I machined the hub into a "U" shape to accept a piece of Al. of about .090" then tapered it and put a joggle in it. Then I turned and knurled a knob for 6061-T6 and secured it with a shoulder bolt, I think. I'm pretty busy just now, but I'll try to get a photo sometime this weekend and try to get it posted. I'm not much for computer stuff so have patience on the photo if you want to see this thing.
