BlueZ31 Posted September 16, 2008 Share Posted September 16, 2008 im sure youve all seen/heard or even used expansion chamber exhausts on 2-strokes (200+hp from a 650cc snowmobile is insane!) but ive always thought that these only worked due to no valves (except on reed-valve motors) which poses no restriction to the sound wave supercharging effect..BUT i got to thinking that with a set of well p/p heads and low restriction intake manifold,along with good smooth-stemmed valves and a cam with a good amount of overlap might allow for a similar exhaust system and the benefits that come with the expansion chamber after looking around i found that a company called "fmf" sells powerbomb pipes for motorcycles that use a expansion chamber (also called a reverse cone system) in the middle of the header pipe to increase low-midrange power (10% increase in power output on a otherwise stock 450cc 4-stroke 1 cyl) considering the vg30e i have displaces about 500cc per cylinder (im guessing) 3 of these on each side in a 3-1 style header system might show some potential. i know equal pulse headers develope the same results but are difficult to make, so has anyone ever thought of using expansion chambers or seen them used on 4-strokes? i know many porsches of the 60's-mid 80's used megaphone exhuasts that use a varying diameter cone with reverse insert to achieve a similar positive pressurizing effect in the combustion chambers, as do many formula 1 motors, but a search on google yielded little results on this subject. i hope someone can shed some light on this subject for me as this might be an awesome upgrade for N/A motors period and might be something alot of the forum might be interested in if it proves worthwhile Quote Link to comment Share on other sites More sharing options...
MONZTER Posted September 16, 2008 Share Posted September 16, 2008 check this http://burnsstainless.com/BTEC/btec.html Quote Link to comment Share on other sites More sharing options...
HowlerMonkey Posted September 16, 2008 Share Posted September 16, 2008 Overlap in valve timing would have to be significant to get any gains. Might work better in a rotary since they have a ton of overlap and also use ports like most two strokes. Quote Link to comment Share on other sites More sharing options...
