restriction to power/fuel lines?
Grumpy' date=' theoretically, what is the maximum horse power that a -6AN fuel line can support? Meaning -6 all the way from the tank to the pump and from the pump to regulator, regulator to carb. Is there a point at which the -6AN fuel line will not support XX HP, regardless of the pump used?
Thanks,
Phil[/quote']
Ive seldom used fittings and lines that small,on anything I intended to race,seriously (usually use 8AN) so I called the tech guys at EDELBROCK and at RUSSELL, both tech guys felt that if everything was optimal you could probably get to 600 hp with the correct pumps, and ,filters and fuel pressure regulators
