Guest Aaron Posted February 19, 2002 Share Posted February 19, 2002 This is not for a Z, but you guys are the best source of information on the net. I searched the archives, and could not find an answer to my question. My dad is building a 49 Pontiac with a Buick 455 and a 700R4 trans. My questions is this: we will be fabricating the trans crossmember this weekend, and we need to know what transmission mount to use. He got the transmission from a builder that used to be on his tool route, and we don't know what it came out of, and it does not have the mount. What year/model of car should we get a trans mount for? I would assume one from a Camaro/Firebird would be the best, but what year models? Thanks in advance. AN Quote Link to comment Share on other sites More sharing options...
Guest Russ240z Posted February 19, 2002 Share Posted February 19, 2002 I don't have my JTR book handy but I remember them recommending a tail housing from a Caprice model 700r4. The reason was to move the mount further from the pan to allow exhaust to be routed easier. Anyone with a book handy can post the part number from GM. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted February 19, 2002 Share Posted February 19, 2002 From what I understand the 1959 thru 1987 Chevrolet standard style trans mount had two bolt holes (3/8 inch diameter?) about four inchs directly apart that connected to the transmission housing and only one bolt to the transmission mount. A fairly simple set up. Look to see what the bottom mounting area of the trans housing you have and if it fits this description requirement. The 1982 up Camaro mount was different and I do not know how different. Someone will come along eventually and answer your question more fully and accurately than I can. Quote Link to comment Share on other sites More sharing options...
383 240z Posted February 21, 2002 Share Posted February 21, 2002 82 - 92 f-body's use a torque arm a good mout from a chevy truck (late model)will fit and be easy to find you do not need the caprice tail housing there will be to bolt holes on the case just before the tailshaft extenion housing that you can use Keith Quote Link to comment Share on other sites More sharing options...
Guest kc6wfs Posted February 21, 2002 Share Posted February 21, 2002 With the caprice tail housing the mounting bolt holes are now lower 1/2" or so making for a better alignment with the rear end in a Z car. Part number for the housing is:$198.03 GM# 8673406 For the mount it's self I used a stock GM camaro I think.$ 25.25 GM# 475940 Thanks, Dave Quote Link to comment Share on other sites More sharing options...
Modern Motorsports Ltd Posted February 21, 2002 Share Posted February 21, 2002 FWIW, the LS1 auto trans mount is a common fbody upgrade for their Lt1 mount that they snap regularly once tweaked for track. The non-GM mounts they found quite harsh and transmitting lots of vibes into the car. I haven't used it personally but local friends including 1320 racers swear by it. Quote Link to comment Share on other sites More sharing options...
