Anyone running Startion/Conquest Wheels on their Z?
Guest jainsworth
The offset for starion/conquest rims:
Tire Size
FRONT: 205/55/VR16 (7" front wheel) or 225/50/VR16 (8" front wheel)
REAR: 225/50/VR16 (8" rear wheel) or 245/45/VR16 (9" rear wheel)
Wheel Size
Front: 7"x16" (7J-16) or 8"x16" (8J-16)
Rear: 8"x16" (8J-16) or 9"x16" (9J-16)
Wheel Offset
Front:
7"x16" mm (in.) 18 (.7)
8"x16" mm (in.) 18 (.7)
Rear:
8"x16" mm (in.) -10 (-.4)
9"x16" mm (in.) 0 (0)
Torque Specifications
Wheel Nuts
Nm 90-110
Ft.lbs. 65-80
8" front wheel:
Front back space 5 1/4" (hub to back lip of wheel)
Front front space 3" (hub to front of wheel lip)
9" rear wheel:
Back back space 5" (hub to back lip of wheel)
Back front space 5 1/4" (hub to front lip of wheel
To tell the difference between the 7/8s for the front and the 8/9s for the rear is to look at the symbol stamped on the rim, the 7/8s are stamped, and the wider 8/9s have an imbedded box around the stamp.
Jimmy
www.starquestclub.com
In that picture there are just some aluminum spacers in place of the struts for rolling around. The stock spring perch is still in there, so normal standard spring/strut combos should work fine.
The Z31 hubs are 19mm 'wider' than the stock hubs, so it effectivly turned made the wheel fit like a 16x8 ET0 on stock hubs.
The rears would require some fender rolling or flares to fit correctly. (with the 9" rims anyways)
