melma! Posted October 20, 2008 Share Posted October 20, 2008 does anyone know what the engine wiring modifications it would take for a 318 in a early 260z. and i was also wondering if there was any pictures of transmission mounts for I believe a 727 (only using till I get enough$$$ for the r134 swap). and maybe measurements of motor mounts,tranny mounts, and driveshaft. thanks -matt Quote Link to comment Share on other sites More sharing options...
Magnum380Z Posted October 21, 2008 Share Posted October 21, 2008 The best thing to do is search through the forum this conversion has been done a couple of times 1 or 2 big blocks and a few small blocks. as far as the mounts go ive seen cut down 80s pu truck mounts work. Quote Link to comment Share on other sites More sharing options...
melma! Posted October 22, 2008 Author Share Posted October 22, 2008 yeah ive looked thru the forum and i know how to get the motor and tranny in. I just dont know the wiring modifications like, where to hook the positive wire of my coil to on the 318. it was on the dizzy for the l26 and it was the only wire that hooked up there. but the 318 has like 3 wires that come off the distributor. there are also no measurements on the forum for this mod. So in case no one wrote the measurements down, once i get her runnin ill post them somewhere. and no one posted pics of tranny mounts, so ill put those on too when its done. I know wiring is pretty basic stuff I just have never done a swap before. so instead of me messing up my whole wiring harness I was hoping one of the dudes that had done it before could help Quote Link to comment Share on other sites More sharing options...
melma! Posted October 29, 2008 Author Share Posted October 29, 2008 ok so, I found out that a j.t.r. manual came with my car, and has a section on wiring. so I guess im good to go. ohh yeah after reading my other posts they seem a little rude im sorry Quote Link to comment Share on other sites More sharing options...
Magnum380Z Posted October 29, 2008 Share Posted October 29, 2008 yeah ive looked thru the forum and i know how to get the motor and tranny in. I just dont know the wiring modifications like, where to hook the positive wire of my coil to on the 318. it was on the dizzy for the l26 and it was the only wire that hooked up there. but the 318 has like 3 wires that come off the distributor. there are also no measurements on the forum for this mod. So in case no one wrote the measurements down, once i get her runnin ill post them somewhere. and no one posted pics of tranny mounts, so ill put those on too when its done. I know wiring is pretty basic stuff I just have never done a swap before. so instead of me messing up my whole wiring harness I was hoping one of the dudes that had done it before could help Your mopar distributor should have 2 wires coming off get a manual any 72-89 dodgefullsize car/truck would work and find out what kind of wires they are and go from there. or run MSD Quote Link to comment Share on other sites More sharing options...
Guest cue340 Posted November 16, 2008 Share Posted November 16, 2008 are you going to be running points or electronic ignition? Quote Link to comment Share on other sites More sharing options...
melma! Posted March 10, 2009 Author Share Posted March 10, 2009 got a chevy 400 and it was garbage so nevermind that idea. the mopar will still be easier. also i took another look and im a retard i guess i was just freakin out so yeah sorry... now the hard part is pullin the 318 out of the van? Quote Link to comment Share on other sites More sharing options...
melma! Posted March 10, 2009 Author Share Posted March 10, 2009 ohh yeah and i will be running points got any tranny suggestions i would like to go manual thanks guys Quote Link to comment Share on other sites More sharing options...
Greg55_99 Posted March 13, 2009 Share Posted March 13, 2009 ohh yeah and i will be running points got any tranny suggestions i would like to go manual thanks guys Supra Turbo: http://board.moparts.org/ubbthreads/showflat.php?Cat=0&Number=3168502&page=0&fpart=all&vc=1 Greg Quote Link to comment Share on other sites More sharing options...
melma! Posted March 21, 2009 Author Share Posted March 21, 2009 i was thinkin about that and just got lost in that thread so im thinkin a mopar a833 trans Quote Link to comment Share on other sites More sharing options...
Magnum380Z Posted May 18, 2009 Share Posted May 18, 2009 that could work but you might have to modify the shift linkage. do a search or contact DOT he had 318/340 powered Z with A833. also are you going to use the OD version? Quote Link to comment Share on other sites More sharing options...
melma! Posted May 20, 2009 Author Share Posted May 20, 2009 whichever one i can find man i am watchin craigslist like a hawk Quote Link to comment Share on other sites More sharing options...
rucus01 Posted May 20, 2009 Share Posted May 20, 2009 i was thinkin about that and just got lost in that thread so im thinkin a mopar a833 trans I would recommend either a 727 or an A833. You will need to purchase an aftermarket shifter like a B&M that uses a cable linkage. They come with brackets that will get the geomtry on the shifts correct. You will also need to look at one of the cable kickdown conversions or run a full manual valve body because the rod likely will not fit in the tunnel. Most of the racing guys prefer the 727 because the internal are lighter than the a833. If you want a 4 speed you will need to do an a833 though, but it will probably cost you time in the quarter. Quote Link to comment Share on other sites More sharing options...
Magnum380Z Posted May 20, 2009 Share Posted May 20, 2009 you can also look at the darts dusters with the 4 speeds they will be od though but that may help you if you wanted overdrive . or as mentioned you can get a 727,but the only thing with that is there is no OD A518 could work it comes in quite a few dodge trucks Daks,vans etc 4th has a big OD ratio i think its .68 i could be wrong though.but it something like that The 518 is basically a 727 with with an elec. OD on the end of it heres more info on the swap:http://www.transmissioncenter.net/SwapInformation.htm kickdown http://www.bouchillonperformance.com/BPEtkdc.asp Quote Link to comment Share on other sites More sharing options...
Greg55_99 Posted April 8, 2010 Share Posted April 8, 2010 Old thread, but this may be useful: http://www.slantsix.org/forum/viewtopic.php?t=35945&highlight=r154 Greg Quote Link to comment Share on other sites More sharing options...
kaos24201 Posted April 24, 2010 Share Posted April 24, 2010 Know of any bellhousings that would work on a R154 to bolt up to a mopar 400?...looking at options for a transmission to go into a z32 Quote Link to comment Share on other sites More sharing options...
Magnum380Z Posted May 3, 2010 Share Posted May 3, 2010 Know of any bellhousings that would work on a R154 to bolt up to a mopar 400?...looking at options for a transmission to go into a z32 Never have heard of one ,but you can check quicktime bellhousings they willhave BHs for the more common tremecs and six speed application..btw this 400 you are using is it stock ? all most all 400s are smog motors 8:1 compression,but respond well to Stroking.. a more modern piston would help it.. A 360LA or MAgnum would be lighter more powerful alternative just my JMHO Quote Link to comment Share on other sites More sharing options...
kaos24201 Posted May 3, 2010 Share Posted May 3, 2010 Never have heard of one ,but you can check quicktime bellhousings they willhave BHs for the more common tremecs and six speed application..btw this 400 you are using is it stock ? all most all 400s are smog motors 8:1 compression,but respond well to Stroking.. a more modern piston would help it.. A 360LA or MAgnum would be lighter more powerful alternative just my JMHO its stock for now im just looking for a replacment for the vg...after its in ill either stroke it to 451 or supercharge or turbo it...havent decided Quote Link to comment Share on other sites More sharing options...
Magnum380Z Posted July 22, 2010 Share Posted July 22, 2010 its stock for now im just looking for a replacment for the vg...after its in ill either stroke it to 451 or supercharge or turbo it...havent decided well thats cool sounds like a neat project oh and Thanks Greg for the Link ! Quote Link to comment Share on other sites More sharing options...
