deeper trans pan
http://www.campbellenterprises.com/automatic-transmission-parts/transmission-pans/aluminum-deep-transmission-pans.htm
http://www.yourcovers.com/newindex2.htm
http://www.partshp.com/Pans.htm
http://www.transmission-specialties.com/catalog/index.php?cPath=98
http://store.summitracing.com/egnsearch.asp?N=400306+304252+115&autoview=sku
http://www.stylintrucks.com/parts.aspx?partfamilyid=5955
Im many cases adding a deeper transmission pan that adds two or more quarts will lower the average transmission temp. at least 15 degrees, while its certainly not as effective as a trans cooler with an electric fan, but far better than nothing at all!, and youdon,t need to run coolant lines, just be aware that if theres limited ground clearance under the car, a deeper trans pan may be a problem when speed bumps and steep driveway access is encountered
