kinknoppix Posted November 20, 2008 Share Posted November 20, 2008 Hi i believe this is my first post and sorry im not introducing myself but i need some quick help after braking the the metal line that runs from the clutch master cylinder to the hydrolic pump slave. I was replace the rubber line and could not get the side where it is in between the bracket off and i snapped the metal line. I will need to replace the whole line that runs on the firewall. It is the highest one beween the try that run on a 78 280z. If i can get some info what this piece is call and where i can get it that will help me sense this is my DD. Quote Link to comment Share on other sites More sharing options...
akangler Posted November 20, 2008 Share Posted November 20, 2008 Just get the same size brake line, line bending tool, and a flaring tool and make your own. Quote Link to comment Share on other sites More sharing options...
blue72 Posted November 20, 2008 Share Posted November 20, 2008 I don't see them listed with MSA, Black Dragon or Z Car Source after doing a quick search. I'd personally scrounge a junkyard, and the local Nissan dealer might be able to help too. If not, then you might need to just buy some new hose and bend it up. If your old fittings are in good shape you could reuse them as well. Quote Link to comment Share on other sites More sharing options...
naviathan Posted November 20, 2008 Share Posted November 20, 2008 Knoppix? Interesting...referencing the famous Linux Live CD? Onto your post. I'd have to agree with the others. Get the appropriate tools for flaring and bending brake tubing, buy the raw materials and do it yourself. Use a string and tape to get a measurement on how long a piece of tube you need. remember to add 2-4 inches to the string length to account for tube length lost in all the bends and any oops in flaring. Quote Link to comment Share on other sites More sharing options...
kinknoppix Posted November 20, 2008 Author Share Posted November 20, 2008 Ok thanks yall i found one in Dallas a guy can strip out for me $50. I can probly make one under $5 myself so thats what ill be doing. Also my username is from a live CD from linux. Im not running it right now but i used to and had it set up to run anything without any problems. : 0 Thanks yall Quote Link to comment Share on other sites More sharing options...
