djbit Posted November 20, 2008 Share Posted November 20, 2008 I ran into this just by googling around. Have any of you used this set up? http://www.14point7.com/JAW/JAW.htm Quote Link to comment Share on other sites More sharing options...
Noddle Posted November 20, 2008 Share Posted November 20, 2008 This is the newer improved version http://www.14point7.com/Widebands/JAW_1_041/JAW_1_041.htm I'm running the v1.03, it works pretty good, the only problem I found it is the output to mega squirts jumps around a little, also I'm still trying to get the 2 to match on AFR, MS is a little off, but I have tuned my car, I have set MS not to use the WB input. When I get some time I will have a fiddle and see if I can get then to sync Nigel Quote Link to comment Share on other sites More sharing options...
djbit Posted November 21, 2008 Author Share Posted November 21, 2008 Oh thanks. Can't this just be runned independent of MS using it's own led display? Quote Link to comment Share on other sites More sharing options...
Noddle Posted November 24, 2008 Share Posted November 24, 2008 Oh thanks. Can't this just be runned independent of MS using it's own led display? Yes, This is what I did before I brought MS, I sorted out my issue with MS and JAWs AFR not reading the same, So I'm a happy camper now. http://14point7.com/forum/index.php?topic=107.msg2256#msg2256 Nigel Quote Link to comment Share on other sites More sharing options...
