turbeau Posted December 2, 2008 Share Posted December 2, 2008 can an L24 distributor work on a carbed L28? if not then i need to wire my universal coil to the L28 Distributor. can you tell me which prong is positive and which negative on the plug from the L28 distributor? thanks for any help Quote Link to comment Share on other sites More sharing options...
Zoobee Posted December 2, 2008 Share Posted December 2, 2008 Anything is possible, but I'm not sure you want to do this. I have an L26 that I am doing the opposite to. I am getting rid of the older style distributor and putting one on from a 1980 zx with the E12 module. From what I have read, the zx ignition setup is superior to what the earlier Z's had. Quote Link to comment Share on other sites More sharing options...
evildky Posted December 2, 2008 Share Posted December 2, 2008 yes the crappy points distributor will work on the l28, but if you look around you can find the instructions to use the electronic distributors which will allow you to rev higher without that annoying sputter up high Quote Link to comment Share on other sites More sharing options...
