torque arm
fl327
just figured a lot of you guys worked on chevy cars enough to know about them pretty good, this questions for a 80s f-body, im putting a th350 in this guys iroc and it has no provisions for the torque arm, what will deleting the torque arm due if left out? i can see crazy oversteer, thats ok, im worried the rear end wont have any support, even though it does have a panhard. anyone?
  • 4 weeks later...
You can also use a Southside machine lift bar kit...comes with subframes,lift bars, and a front crossmember (like lader bars). A buddy of mine had an 82 TA with an unusual setup that worked...the original LCAs were boxed, and had a tab welded to the front top of them with a link (steel rod with spherical rod ends on both ends) that connected to another bracket welded to the rearend. It was definitely a home brewed setup (done by a previous owner), but it worked, and was probably cheap to build. The pinion angle was adjustable, which would be a good idea anyway for maximum bite.
