BAlford Posted July 8, 2002 Share Posted July 8, 2002 What kind of a rear end is this? We pulled a rear end out of a 1980 parts car and it was a R180. We have another parts car, a 1982 but the rear end is a 3.9 to 1 ratio, so we do not wnat to use it. We took pictures of the rear end of the car that we are driving, a 1982 280ZX 2+2, and it does not look like either of the rear ends in the repair manual. What is this? Please check the pictures on the web page below: http://www.waskomtexas.com/zcar/re_car/rear_end.html You don't need a password, just click OK. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted July 8, 2002 Share Posted July 8, 2002 Thats a later ZX R200 rear end with CV joints right? Regards, Lone Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted July 8, 2002 Share Posted July 8, 2002 I agree with Lone...Ocbaar just bought a 1973 240 Z with this style rear end installed with the CV joints which was reported to be out of a 1982 ZX Quote Link to comment Share on other sites More sharing options...
BAlford Posted July 8, 2002 Author Share Posted July 8, 2002 I checked the manual some more and find that they cal it a tri-pod joint, I think is the term. If I can not find the same type at the salvage, can I switch to the open u-joint rear end? Also is the CV type better? Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted July 8, 2002 Share Posted July 8, 2002 I hear the CV is stronger and takes to a lowered suspension with less complaint. Quote Link to comment Share on other sites More sharing options...
Guest greimann Posted July 8, 2002 Share Posted July 8, 2002 You can't directly replace a CV joint with a u-joint half shaft. The connection at the outer hub is different. The CV joints are stronger. I recommend keeping the setup you have and fixing whatever is wrong. Quote Link to comment Share on other sites More sharing options...
