Guest Frank280z Posted June 6, 2001 Share Posted June 6, 2001 I have heard of sealing problems...... Quote Link to comment Share on other sites More sharing options...
Guest RON JONES Posted June 7, 2001 Share Posted June 7, 2001 Yea Rick,I wouldn't go with an alumunum block.I don't know the details,but I know there are some kind of problems that can happen,sealing being one of them. Quote Link to comment Share on other sites More sharing options...
Guest JAMIE T Posted June 7, 2001 Share Posted June 7, 2001 I have heard stories of Aluminum blocks cracking due to being hot and getting spashed with lots of water(like going through a deep puddle). But this may be bogus info since Land Rovers have used Aluminum blocks for ages. My Northstar is all aluminum, but it has some pretty trick gaskets. They really worked the bugs out of these things. Jamie Deathstar Z Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted June 7, 2001 Share Posted June 7, 2001 I think if you drove it into a icy creek, then yeah it'd probably have an issue, a little water from a puddle is probably going to evaporate on the hot block being as its heat source is greater than the small amount of cold water. I suspect as you all have mentioned its sealing and the reason might be disimilar metals heating and cooling can do some rather strange things. I know they had issues decades ago with aluminum engine blocks and the steel sleeves getting loose or cracking. I had thought those were resolved with engines like the LS1? Regards, Lone Quote Link to comment Share on other sites More sharing options...
Z-Dreamer Posted June 7, 2001 Share Posted June 7, 2001 Fast Frog, why not get the LS1 engine kit from GM Performance? $5659.95 gets you a NEW LS1 rated at 320hp/345Ft/Ibs, comes with injectors, manifolds, flexplate, ECM, wiring harness and warranty! There is alot of HP stuff now available for the LS1. Food for thought. Checkout www.paceparts.com/ under crate engines. Mark Quote Link to comment Share on other sites More sharing options...
Guest Fast Frog Posted June 7, 2001 Share Posted June 7, 2001 I've heard rumblings from a few sources that going with an alum block together with alum components may not be the best setup. Aside from the cost($4000+), anybody know why?? Or is what I'm hearing just BS? Rick Quote Link to comment Share on other sites More sharing options...
Administrators SuperDan Posted June 7, 2001 Administrators Share Posted June 7, 2001 I thought I remember reading somewhere that the big problem with the Al SBC blocks was that they sufferd from core shift really bad and were pretty much toast after about 10k miles of street use. Dan Quote Link to comment Share on other sites More sharing options...
Guest Fast Frog Posted June 7, 2001 Share Posted June 7, 2001 Thanx, guys!! I'll probably stay with a cast iron block!! Quote Link to comment Share on other sites More sharing options...
pparaska Posted June 7, 2001 Share Posted June 7, 2001 Many if not all of the Al SBC aftermarket blocks are VERY beefy, and this negates a decent amount of the weight savings. No numbers handy, but this topic came up before here. Quote Link to comment Share on other sites More sharing options...
BLKMGK Posted June 7, 2001 Share Posted June 7, 2001 LS1s? http://www.lt1s.com/ claims to have them and LT1s too. Quote Link to comment Share on other sites More sharing options...
