shadesh Posted December 17, 2008 Share Posted December 17, 2008 I have a 1975 280Z which I am converting to SUs. I have a N42 head and block and the head has the hole for the mechanical fuel pump. What do I need to do if I want to use a 240 mechanical pump? Does the cam pulley or anything on the engine has to be changed or can I just bolt on the mechanical pump??? Thanks in advance.. Quote Link to comment Share on other sites More sharing options...
shadesh Posted December 17, 2008 Author Share Posted December 17, 2008 Anybody? Quote Link to comment Share on other sites More sharing options...
jasper Posted December 17, 2008 Share Posted December 17, 2008 If you remove the valve cover, you can see if there is an eccentric on the cam gear. Or just go with an electic pump. Quote Link to comment Share on other sites More sharing options...
shadesh Posted December 17, 2008 Author Share Posted December 17, 2008 I am sorry but how do I identify the eccentric on the cam gear? what does it look like? Quote Link to comment Share on other sites More sharing options...
jasper Posted December 17, 2008 Share Posted December 17, 2008 Quote Link to comment Share on other sites More sharing options...
shadesh Posted December 17, 2008 Author Share Posted December 17, 2008 ok.. now I see it. Thanks jasper. That helps... My engine probably does not have it since its a L28 with EFI. Now I have to find the eccentric.. Do I have to buy the eccentric only or do I have to buy the sprocket and all? Don't know if my question makes sense.. Quote Link to comment Share on other sites More sharing options...
naviathan Posted December 17, 2008 Share Posted December 17, 2008 I have one. Someone put an L26 bored over to a L28 in my 77 and they left the eccentric on the cam bolt. On a side note, why are you going from an electronic metered fuel leak to a mechanicaly metered fuel leak? Quote Link to comment Share on other sites More sharing options...
shadesh Posted December 17, 2008 Author Share Posted December 17, 2008 For now SU's seem way to be a cheaper way to run my car. I am planning on using the EFI at some point when I can afford to have my injectors cleaned and to purchase all the sensors and so forth.. I think EFI is a good way to go but you have to be ready to freshen up some of the components which mind you are 30 years old. Naviathan, pm me on the eccentric. I am in southern california.. Quote Link to comment Share on other sites More sharing options...
