t400 in with 350.
is the 400 easy fit into the z. i have only done a t5 on previous conversions. what should i expect slapping this under. also. is it longer or shorter in full then the t5. will the driveshaft have to be longer or shorter then a normal jtr conversion with a t5. also. does the conversion flange work on and chevy driveshaft. mine is coming out of a 69 chevy pickup. thanks
yoke is the same t5/th350/t400/2004r/and M21
it is around the same length maybe a little longer than a M21, its pretty short, but the 400 is a very wide fat trans, tight fit for sure, if you have the t5 driveshaft already try it to see if it works it just might.
