Maxxis MA-V1 225 45 16
Anyone used them? I talked to the manager at Les Schwabs today (friend of ours since we do so much business there) and he reccommended the maxxis. It will run me $500 mounted and balanced, which was after a slight discount.
Heres some specs from the website. These will be going on my 16x8 RBR's.
Part Number
TP39590000
Size
225/45R16
Service Description
89V
Side Wall
BSW
Overall Diameter (inches)
23.9
Section Width (inches)
8.80
Max Psi
44
Max Load (lbs)
1,279
Rim Width (inches)
7.50
Tread Depth (inches)
10/32
They look similiar to my sumitomo's that i have on the back end of the Z. I'm running 245/45/16's though... mine were cheap, like $73/each from tirerack.com the 225/45's are only $68/each... worth a look
225/45ZR16
Load Index 89 = 1279lbs (580kg) per tire
Speed Rating “W” = 168mph (270kph) 89W SL Treadwear: 160
Traction: A
Temperature: A160 A A 1279 lbs.
44 psi
10/32"
