Please enlighten me. speedometer gear problems
ottoauto
i have installed a 5-speed. i've been working out certain problems (first had the wrong collar, then my pedal was too worn to work correctly with the 5-speed, and now....). My speedmoeter isn't working. the transmission had the same colored gear as my 4-speed (this seems like it has been switched) and the screw that holds it was loose (like it may have been chenged). As far as im aware i have a short ratio 5-speed out of an early 80's zx, and still have an r180 diff, but i would like to switch it out. Anyway, i put the transmission in and i have no reading on my speedo in my 1972 240z. Im wondering if i should have a different colored gear, or if i should maybe be woring about internal transmission gears?
