Guest 240Z_72 Posted August 12, 2002 Share Posted August 12, 2002 How do u guys insulate an aftermarket shifter? I have a B&M Z-Gate. I can seal the edges of the mount to the to of the tunnel, but how do you keep the hot air from coming right out the top of the shifter housing? The whole slot is open, is there a rubber sealer missing I wonder? -Kurt Quote Link to comment Share on other sites More sharing options...
BLKMGK Posted August 12, 2002 Share Posted August 12, 2002 Cable shifter right? I used duct tape to seal the area around my shifter hole on my stick shift. IF this is a cable shifter then you ought to be able to tape up everything around the cables and seal it up good. Quote Link to comment Share on other sites More sharing options...
BAlford Posted August 12, 2002 Share Posted August 12, 2002 I welded a steel box that slips down through the hole in the center hump where the original shifter went for my B&M shifter. I used about 1/6" steel, it has 4 tabs that set on top so I could bolt it down. I made it fit very close on the underside and used silcone calk. Nothing comes through and it is solid. Quote Link to comment Share on other sites More sharing options...
