This looks like a good coil setup.
1 fast z
I also wonder if it is infact only three coils? If so 1,6 need to be fired at the same time for a wasted setup. I guess one of us needs to have one in hand to find out everything about it. But it sure looks alot better than most other setups.
  • Administrators
It sure looks like a 3 coils on top of the body/frame,i.e. wasted spark. My guess is the High Tension leads for the 1-6, 2-5, 3-4 pairings are strategically routed in the plastic body/frame.
Do you know if the igniters are built into the coils or is it just the coils and it utilizes a separate ignition module such as the Ford EDIS-x arrangement?
From the number of pins on the connector you can determine if there are coil drivers built in or not.
If all connections are grouped into one connector:
4 pins = no drivers built in
5 pins = drivers built in
Pete
I dont know, but I would guess that there are not any drivers. I would just use a EDIS 6 module to fire it.
As near as I can tell, Chrysler never built an ignition system with external coil drivers; they always integrated the drivers into the ECU. The only examples of "Chrysler" engines I've seen that had both EFI and an external ignition module were ones built by Mitsubishi.
