bmwe30 Posted January 15, 2009 Share Posted January 15, 2009 I have a 78 280z, she's pretty sweet well the main question I have is how do I do the clutch set up? what transmision should I look for? yes I have to have a stick, I get bored other wise haha I want a 350, what kinda of MPG numbers can I expect from a stock to lightly modified small block with a four barrel carb? ( I know these cars are very light so that will help) thanks Quote Link to comment Share on other sites More sharing options...
CJBrian Posted January 15, 2009 Share Posted January 15, 2009 Get this book it should answer all your questions. http://jagsthatrun.com/Pages/Datsun_Z_V-8.html Clutches are easy just use the clutch for the trans you pick and use the master cylinder and fittings suggested in the book. Common trannys to look for are T-5 5spd and T-56 6spd. Most commonly found in camaros and firebirds. Quote Link to comment Share on other sites More sharing options...
bmwe30 Posted January 15, 2009 Author Share Posted January 15, 2009 what about gas mileage? this will be my daily driver untill I find a junker to drive around, Quote Link to comment Share on other sites More sharing options...
CJBrian Posted January 15, 2009 Share Posted January 15, 2009 what about gas mileage? this will be my daily driver untill I find a junker to drive around, Depends on your setup and driving sytle but usually around 20-25 mpg hiway. Quote Link to comment Share on other sites More sharing options...
bmwe30 Posted January 15, 2009 Author Share Posted January 15, 2009 what kind of set ups would produse good gas mileage?, I'm not looking for huge power just 300 tops would a 400 small block be ok? as far as gas mileage? Quote Link to comment Share on other sites More sharing options...
CJBrian Posted January 15, 2009 Share Posted January 15, 2009 what kind of set ups would produse good gas mileage?, I'm not looking for huge power just 300 topswould a 400 small block be ok? as far as gas mileage? The person that can answer the engine setup question the best is probably Grumpy in this thread. http://forums.hybridz.org/showthread.php?t=139049 Are you planning on finding a complete running stock engine to drop in or building one? If your looking for stock that gets good mpg you will probably want to stay away from 70's stuff because of the bad combustion chamber designs. If you are planning on building something the lighter and more free flowing you can make the engine the better mpg it will get. I dont know what kinda of mpg you are looking for and your budget but it might be hard to get with a big cast iron V8 in a sports car. Depending on your budget you might consider newer efi V8's and LS engines. You also have to consider the trans and rear end gearing and total weight of the car. Quote Link to comment Share on other sites More sharing options...
