Gear ratios in R200's
Is there any quick way to tell my model year, etc what gear ratio the R200 diff in my 75 280z is? Its a 4-speed manual if that helps. Does it say on the outside of the diff?
You can always put some tape on the back of the driveline as a reference line, jack up the back, have a partner hold one wheel while you turn the other and count how many times the driveshaft turns. If it turns 3.5 times, you have a 3.54. Or just pop off the back cover and look for the numbers on the gears, divide the small number into the big number and the answer will be your drive ratio.
Regards,
Lone
