nine8transam Posted January 21, 2009 Share Posted January 21, 2009 ok heres my problem i found coolant shooting out of my #3 spark plug hole when i was checking compression well i looked at the head after i pulled it off to swap out the head gasket and didnt see any problems with it but i didnt realy look becasue being hard headed i was dead set that it was the head gasket well im still having the problem. but i did **** up the timing so it actualy blew coolant outside of the head gasket that never leaked before and i think with my timing way off that its not open/closing the valves and building to much compression but any way if anyone has any advice for me it would greatly be appreciated because im at a stand still at the moment im going to take the head and get it checked Quote Link to comment Share on other sites More sharing options...
tech9 Posted January 21, 2009 Share Posted January 21, 2009 There was coolant before you changed the gasket, and after? Quote Link to comment Share on other sites More sharing options...
nine8transam Posted January 22, 2009 Author Share Posted January 22, 2009 yea its depressing i guess its the head but i cant visualy see any cracks but and i rotated the engine to check the cylinder walls also and cant see any defects. is there anywhere else i should check? but im not going to get the head checked because the cheapest i can get it looked at is 125 and i found a junk yard with lots of l28 and a maxima 810 2.4l for 150 and they will remove them Quote Link to comment Share on other sites More sharing options...
