Noddle Posted January 24, 2009 Share Posted January 24, 2009 Hi, I'm in the process of putting a turbo on my N/A L24e (5-7 psi, with megasquirt), and I want to know if I can use the existing fuel regulator or are these different to the turbo ones. The reason I ask is that I'm not sure what will happens to fuel pressure, when boost is applied on the regulator. Nigel Quote Link to comment Share on other sites More sharing options...
Brad-ManQ45 Posted January 25, 2009 Share Posted January 25, 2009 AutoZone shows the same FPR for NA and Turbo... If there is a vacuum line going to the intake to the FPR you should be fine with the NA one. Quote Link to comment Share on other sites More sharing options...
