KingsKid Posted February 1, 2009 Share Posted February 1, 2009 Trying to hoist my motor to change the oil pan. I have the factory manual and they show brackets called engine slings. They are not good drawings because it doesn't even show were exactly they mount. I don't have the brackets and was woundering how to hoist my motor up so I can get this oil pan changed. Any help? If you have any pics would be awsome. I tried searching the forums but didn't find anything. Quote Link to comment Share on other sites More sharing options...
rise Posted February 1, 2009 Share Posted February 1, 2009 you can hoist from a number of spots I sometimes use the ex manifold studs if the ex is removed but in your case eisiest might be to sling a strap or chain around the mounts and over the top. Quote Link to comment Share on other sites More sharing options...
KingsKid Posted February 2, 2009 Author Share Posted February 2, 2009 thanks, I use mounts. Worked great. Quote Link to comment Share on other sites More sharing options...
Comrade_Charlie Posted February 11, 2009 Share Posted February 11, 2009 I use the little bracket that extends above the powersteering, and the little bracket on the driver head with the 2 holes in it, just run a bolt through the hole with it going through a chain. done it like that everytime I lift a vg out. Quote Link to comment Share on other sites More sharing options...
