Clayton Hall Posted February 3, 2009 Share Posted February 3, 2009 Im currently in the process of putting a s13 sr20det into my 280z and i was wondering if i have already got the s13 motor and wiring harness and decide to do the s13 dash conversion can i just use the s13 gauge cluster? Quote Link to comment Share on other sites More sharing options...
Clayton Hall Posted February 6, 2009 Author Share Posted February 6, 2009 anyone? Quote Link to comment Share on other sites More sharing options...
chris556452 Posted February 6, 2009 Share Posted February 6, 2009 Well, if you're using the s13 engine, electronics, and dash, what would stop you from using the instrument cluster? If you're using the dash, what would you put in there instead of the stock unit? -Chris Quote Link to comment Share on other sites More sharing options...
Nizm0Zed Posted February 7, 2009 Share Posted February 7, 2009 are you planning on using the stock ECU from your donor? because if you are, it will make the job VERY easy if you can use the entire body loom, so the instruments, climate control, ECU, everything. basically, what you would want to do, is adapt your lights, steering column switches, and other general body parts, into the S13 loom. Quote Link to comment Share on other sites More sharing options...
