Guest Mr. Big Business Posted October 31, 2002 Share Posted October 31, 2002 Well, I've jumped in with both feet! ZZ4 is on the way, and Bob Weir is sending me the bellhousing/hyd. bearing setup to bolt on the T56 I have in the garage. Now, for my question. According to bob weir, I should use a clutch and pressure plate from a, '84 to '91 Z28, with muncie transmission. Can any of you gurus give me the part numbers for that clutch and PP? The ZZ4 I'm getting already has a 10.5 inch (153 tooth) flywheel, if that makes a difference. Thanks, Henry Quote Link to comment Share on other sites More sharing options...
Mudge Posted November 1, 2002 Share Posted November 1, 2002 A dealership should be able to tell you, or try www.CamaroZ28.com msg board. Quote Link to comment Share on other sites More sharing options...
