APEXi SAFC II install, Ive got no tach signal? RB25DET S2
rayaapp2
I just installed my SAFC II into my car and Im setting it up so I can install the knock signal wire. So anyone that has done this setup knows that in order to hook up the little purple wire(knock signal) you need the RPM signal to work as well.
I cant get a signal. Im pulling the signal from Pin 7 and Im routing it to the green wire on the SAFC. The SAFC is at 0 RPM. I checked I have .2 ohms from the ECU at pin 7 to the SAFC at the internal connector.
Temporarily I have connected the the green wire to pin number 1 and set the SAFC Cylinder count to 1.
Whats the deal?
