Guest jens Posted November 7, 2002 Share Posted November 7, 2002 Can i avoid the tv cable if i use this valvebody How about the overdrive can it still work or? http://store.summitracing.com/partdetail.asp?part=25370 Quote Link to comment Share on other sites More sharing options...
383 240z Posted November 9, 2002 Share Posted November 9, 2002 The answer is NO!! The TV cable is used to control the line pressure as you increse the load on the trans you need to increase the psi. the cable is not that hard to set up what are you using for an induction system? Carb or EFI? Keith Quote Link to comment Share on other sites More sharing options...
Guest jens Posted November 9, 2002 Share Posted November 9, 2002 Rochester Quote Link to comment Share on other sites More sharing options...
383 240z Posted November 10, 2002 Share Posted November 10, 2002 Is that Rochester Mech. fuel inj? probely not it is rare and pretty expensive and not a very good high perf. unit if it is a Rochester carb (Q-Jet) I have the bracket you need. You can have it just cover the shipping. Keith Quote Link to comment Share on other sites More sharing options...
