Guest De Schmaydee Posted November 19, 2002 Share Posted November 19, 2002 ..just had a used t-5 put in my 82zxt...replaced the clutch,flywheel,throw-out and pilot....when i go from 1st to 2nd (driving casually)the thing "kinda" grinds..or more like...i feel the gears meshing like a vibration in the shifter.....does it about 90% of the time....is 2nd going out?...downshifts into second fine...and no prob w/the other gears....or might it be the new clutch/flywheel etc.....? thanks, ....s Quote Link to comment Share on other sites More sharing options...
fl327 Posted November 19, 2002 Share Posted November 19, 2002 check to see if you are getting proper engagement at the pedal. somewhere in a haynes manual they should have pedal height specs for you. Quote Link to comment Share on other sites More sharing options...
