is there anyway to make a r180 hold up to lots of power w/o
Guest 2002sentraSER
Guest 2002sentraSER
i won't be able to afford to do a new rear end right away is there anyway to strenthen it enough so that i don't break it in the mean time of getting my 9" ford rear end because i have no truck to tow the car home
Depends, if you are going to drag race the car. I would say no, if your just driving on the street it should be no problem. The problem i had with the R-180 was the stub axels breaking inside the differential right where the splines end . They are hollow to allow the bolt to go through and don`t provide enough strength for a drag launch with sticky tires.
