Guest 2002sentraSER Posted November 24, 2002 Share Posted November 24, 2002 i won't be able to afford to do a new rear end right away is there anyway to strenthen it enough so that i don't break it in the mean time of getting my 9" ford rear end because i have no truck to tow the car home Quote Link to comment Share on other sites More sharing options...
Pop N Wood Posted November 24, 2002 Share Posted November 24, 2002 Yeah, don't hammer it The weak link in the R180's is the spider gears. Weld up the spider gears (using the proper alloy welding rod, the JTR manual has the correct one) and the only thing you will have to worry about are the U joints. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted November 24, 2002 Share Posted November 24, 2002 Depends, if you are going to drag race the car. I would say no, if your just driving on the street it should be no problem. The problem i had with the R-180 was the stub axels breaking inside the differential right where the splines end . They are hollow to allow the bolt to go through and don`t provide enough strength for a drag launch with sticky tires. Quote Link to comment Share on other sites More sharing options...
