rackolamb1 Posted February 28, 2009 Share Posted February 28, 2009 Hey guys, I just opened up my T5 from an 83 turbo donor to make sure everything is ok, and to reseal the case so I don't get any leaks after installation. My question is, what is the trick to install the top cover with the shift forks? I thought I had everything in nuetral and lined up properly. When I put it back together to test it, the shifter was stuck. The tranny shifted fine before, so i'm assuming it moved on me when i put it together. Should I put this into a gear before putting it together? Thanks.... Quote Link to comment Share on other sites More sharing options...
rackolamb1 Posted March 1, 2009 Author Share Posted March 1, 2009 OK, I figured it out. I found a nice disassembly and reassembly manual from drivetrain.com... See link for pdf of manual.. http://www.ttcautomotive.com/English/media/pdfs_autogen/T-5_Service_Manual.pdf Quote Link to comment Share on other sites More sharing options...
