water injaction
Is water injection safe?
Yes
But ANY mod done wrong can hurt. If you don't control the injection you can hydro lock a motor. Any kit installed correctly is safe.
Will water injection make more horse power?
Water injection primarily cools the air charge and combustion chamber helping prevent detonation. Both help a motor run more timing which often helps a motors performance.
Injection is MOST beneficial for boosted motors, but it can help naturally aspirated motors.
Many use windshield washer fluid -20F, but I doubt you will find that where you live. Methanol and water is often used for octane and cooling.
I use methanol and water injection and it allows me to run higher boost with more timing. I run 14 psi and 27 degrees timing. I added a second stage and expect to pick up more. I was injecting M7 now M4 and M5 and engine wants more.
Hope that helped
