marcus70ZT Posted December 10, 2002 Share Posted December 10, 2002 just wanted to share what i found out about the nissan T5 tranny and the gear oil/ATF issue since i've seen some mis-information in the past. i just picked up a pretty nice 82ZXT with a 5 speed (for $400!) so i've been recearching... "At 09:12 PM 12/8/02 -0800, you wrote: >what gear oil do you recommend for the T5 used in the >1982 nissan 280ZX turbo? i've heard conflicting info >on using ATF versus a light synthetic gear oil like >redline MTL. We use dextron III or Mobil one multi purpose ATF. Never use MTL Thank you, Paul Cangialosi www.5speeds.com Originators of JT5 and JT4 Transmissions. At 10:35 PM 12/8/02 -0800, you wrote: >thanks for the quick reply. so just to clarify, you >recommend ATF in both the world class and non-WC T5's? Yes I do. It has nothing to do with the roller bearing. Gear lube will not flow properly in that box. Rather than mess with people's opinions or second hand info , the FACTORY overhaul manual states Dextron II or III for both transmissions. I have personally seen non WC boxes burn up from gear lube use. Thank you, Paul Cangialosi www.5speeds.com Originators of JT5 and JT4 Transmissions." Quote Link to comment Share on other sites More sharing options...
