Guest Philanthr0py Posted December 9, 2002 Share Posted December 9, 2002 I'm swapping over a R200 into my 240z. Is the rear cross member and mustache bar the only things needed for the swap? and what's a good company to buy new bushings for the mustache bar? Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted December 9, 2002 Share Posted December 9, 2002 Yes,some say that you do not need the crossmember...keep both.... MSA/I had luck with theirs. Ground Control, Suspension Techniques... e Bay sellers. If the M bar bushings are good do not change them. Quote Link to comment Share on other sites More sharing options...
ianz Posted December 12, 2002 Share Posted December 12, 2002 why not change the M-bar bushings?? has anyone figured out a way to raise the back of the diff easily?? Quote Link to comment Share on other sites More sharing options...
jaime240z Posted December 12, 2002 Share Posted December 12, 2002 I just did the same swap on my '72. All I used was the R-200 and corresponding must. bar. I used the original crossmember. I also replaced the bushings with Energy Susp. units. Also, if you're planning on changing the bushings to the rear control arms this would be a good time. You'll have them half way off for the swap. As far as lifting and lowering the diff. I used a regular floor jack with no special adapters. I was able to manage by myself, but a partner would've been very helpful for that part. Remeber to use jack stands since the whole rear suspension will be pretty much taken apart. And remember to turn the front diff. mount 180 deg. Hope this helps. Jaime Quote Link to comment Share on other sites More sharing options...
jaime240z Posted December 12, 2002 Share Posted December 12, 2002 Originally posted by ianz:[QB]why not change the M-bar bushings?? Well, if they're still good, then why change them. Mine were not good. To take the old ones out, I just burned them out with a torch. Just be carefull not to warp the metal. Then I pressed the new ones in with a bench vise. Quote Link to comment Share on other sites More sharing options...
