TXCASE801 Posted March 9, 2009 Share Posted March 9, 2009 please help. i have a 78 (11-77) 280Z, new fuel pump, new fuel pressure reg. the car runs for a bit, (no wide open throttle, hesitates a lil) then finally will start sputtering then will die ( engine will spit and pop from the throttle body). after the car will not start. if i pull the in fuel line off (from the fuel filter) gas will spray out with a ton of pressure. the car will start eventually but will die the same way in just a bit. thanks jj Quote Link to comment Share on other sites More sharing options...
