Guest Anonymous Posted December 23, 2002 Share Posted December 23, 2002 Is it necessary ( or wise )to change the clutch plate, pressure plate, throwout bearing, and fork when a clutch rebuild is needed? fly wheel facing? each and every time?? or can you get away with inspecting the components and judging what to replace? Quote Link to comment Share on other sites More sharing options...
Synlubes Posted December 23, 2002 Share Posted December 23, 2002 IMO - YES TO ALL!!! If the fork has been replaced less than 30k, inspect it and see what it looks like! Don`t foreget to change the pilot shaft bushing also! Lube the new one after you install it with some wheel bearing grease! Take a look at the frt trans seal and engine rear main seal while everything is out! Quote Link to comment Share on other sites More sharing options...
