Guest Pegasus76 Posted December 31, 2002 Share Posted December 31, 2002 Whenever I hit the gas a my rpms rise but I don't pull, then the rpms go back down then it goes...What do I need to repair? Quote Link to comment Share on other sites More sharing options...
Wagz Posted December 31, 2002 Share Posted December 31, 2002 Pegasus - Give us a little more info. Are you running a manual or an automatic? Have you ruled-out the basics: clutch slipping (manual), low trans fluid (auto), etc? Quote Link to comment Share on other sites More sharing options...
Guest Pegasus76 Posted December 31, 2002 Share Posted December 31, 2002 Sorry. It's a T-5 camaro transmission (manual) it makes a whining noise as well...Could it be low fluid? NOt sure if the clutch it slipping but if I am on the highway in 5th gear and I give it gas the rpms rise then go back down then the car goes. Quote Link to comment Share on other sites More sharing options...
Guest greimann Posted December 31, 2002 Share Posted December 31, 2002 I hate to be the bearer of bad news, but if a transmission is making unusual noises, the damage is done. It is probably a bearing with damaged rolling elements. You should be using ATF in that T5 and not gear oil, in case you are changing fluid. Ditto on the slippage. Time for a new clutch. Quote Link to comment Share on other sites More sharing options...
Wagz Posted January 1, 2003 Share Posted January 1, 2003 The whining noise could mean it's low on gear oil. I would start by checking the oil level. It could just be wear and tear on synchros, etc. The slipping is most likely a worn-out clutch. You might be able to adjust it out, but you're probably due to change it out soon. Do you know how many miles are on the clutch/tranny? Quote Link to comment Share on other sites More sharing options...
Guest De Schmaydee Posted January 2, 2003 Share Posted January 2, 2003 ....i agree w/g ...(good to see the dawg back)...are you sure about the "camaro" thang...they wont usually fit unless you have a v-8......usually we have a borg-warner 5 spd (or a nissan) ...but it sounds like your clutch is slipping....the noise doesnt have anything to do w/the slip...its just a bad sign that somethings gone wrong w/the drive train..........s Quote Link to comment Share on other sites More sharing options...
Guest Pegasus76 Posted January 3, 2003 Share Posted January 3, 2003 Thanks for the help guys, I'm going to buy my friend's clutch. He had recently wrecked the front end of his car He is bummed about that but atleast he is alive. He is parting out all the good parts in his car and he has a performance clutch. (86 Camaro) Again thanks guys, and I have a 350 SBC Schmaydee... Quote Link to comment Share on other sites More sharing options...
