Anyone bypass any of the coolant lines on rb??
dizzle
Trying to limit the amount of hot coolant running through the the intake man on my RB20det. Has anyone ever done this, and if so which ones can i eliminate? I am pretty sure that the one that runs across the top infront of the fuel rail can go. But the do I just loop the outlet at the heater hose to the one coming off of the thermostat housing? I know the lower water pipes run into the head so those have to stay. But my new turbo is not water cooled so I already took off the hard line and that y'ed into a bunch of stuff.
Any help appricated...
I agree with Evan,
The only ones you can do with out are the throttle body ones, and to your heater core. You could tidy them up though using different hoses not that it matters as you won't see the hoses anyway once the intake is on.
Chris
