Guest Anonymous Posted January 5, 2003 Share Posted January 5, 2003 everyone, i have done a search on the site and havent found one picture of an vlsd, i have a friend that just pick a rear end up out an 88 and thinks its a lsd, i think its a vlsd.and why wont the vlsd fit in a 240 w/ 280ZX CV's?different spline count? help?? thanks Quote Link to comment Share on other sites More sharing options...
Modern Motorsports Ltd Posted January 5, 2003 Share Posted January 5, 2003 John, the viscous has a totally different input design on the diff inputs, it uses shafts unique to the differential. Did your friend by chance get the shafts that were with the differential? I'd like some measurements on viscous shafts.....perhaps they'll bolt in with my newer Z31 adaptor. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted January 5, 2003 Share Posted January 5, 2003 ross, he did get the half shafts. i can measure them if you want. also does anyone have a picture of the rear end? we popped off the rear cover lastnight. we didnt see any "discs" inside the 3rd member. the rear cover has major fins at the bottom. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted January 5, 2003 Share Posted January 5, 2003 ross, also what does your z31 vlsd adaptor look like?can you tell me the exact length of the 280zx cv half shafts? thanks Quote Link to comment Share on other sites More sharing options...
Dp351zcar Posted January 6, 2003 Share Posted January 6, 2003 The side stubs are the problem with a vlsd, they are diffrent lengths and are made for CV joint halfshafts and the halfshafts will not bolt into a early Z. Hope this helps. Don Ross you beat me just by a couple minutes Quote Link to comment Share on other sites More sharing options...
Guest 240hybrid Posted January 7, 2003 Share Posted January 7, 2003 I was looking at a viscous LSD for a moment, but went with Clutchpack. From what I was told when I consulted some people on using that diff. they said you can use it if you have the CVshafts with it. I dont know if you'll have any binding issues though. One good thing about those Viscous diffs. is that they dont wear out as quickly as a clutch type. I havent installed a diff from that year/model, but I dont think you'll run into any problems bolting it up, although you'll never know till you try. As for the companion flanges, you'll prob want to get a set of 280z stub axles(stronger) and Ross C at modern-motorsports.com can make up a pair of CV adapters for a 300zx CVs for you. Hes making a set for me and should be recieveing them soon. Thats all the info. I know about a viscous diff, but the only way you'll prob. know for sure is to try it. good luck Quote Link to comment Share on other sites More sharing options...
RB30-ZED Posted January 7, 2003 Share Posted January 7, 2003 Ive fitted a R180 VLSD to my car, the outer case is the same as the other units, but you do need to get the shafts that came with the unit as the left hand one has a extra splined section to engage the viscous unit, the right hand stub is the same as the non LSD units. I machined down the inner CV"s (as that is all I had) and made flanges out of them to bolt my drive shafts to. Im sure its the same deal with the R200 units. Steven Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted January 7, 2003 Share Posted January 7, 2003 zed, can you send me a picture of your set up, im not quite clear on your machining. thanks Quote Link to comment Share on other sites More sharing options...
