Indey Posted March 17, 2009 Share Posted March 17, 2009 Alright guys, so my girlfriend picked up a 76 280z and I do have a few questions about it. First and foremost it feels like it has a 4 speed transmission. It is somewhat hard to shift, and the shifter is very loose, so might there be any fixes for that. As said it feels like a 4 speed, reason is, It will go into 1,2,3,4 and reverse, and then when i try to go to where 5th would be it dosent even feel like theres a notch for it to slide into 5th. SO cliffs for that first part =P - Did this particular year Z come in a 4 speed manual? - Shifting is very hard, possible synchros? - Shifter is very loose any possible fixes? Next off There is a rather large clunk sound coming from the right rear side of the car when going over the reflectors on the freeway so around 60-70 mph, are there any possible causes for this? and yes all the tires are inflated properly =P and that's about it... so any help is appreciated guys and here's a terrible cell phone pic of her car! Quote Link to comment Share on other sites More sharing options...
johnc Posted March 17, 2009 Share Posted March 17, 2009 - Did this particular year Z come in a 4 speed manual? Yes. - Shifting is very hard, possible synchros? Change the fluid and fix the shifter first. - Shifter is very loose any possible fixes? Search "Shifter Bushing" There is a rather large clunk sound coming from the right rear side of the car when going over the reflectors on the freeway so around 60-70 mph, are there any possible causes for this? and yes all the tires are inflated properly Check the control arm bushings, gland nut, anti-roll bar end links, wheel nuts, e-brake cable, rear brakes, insulator mount, and go buy a shop manual for the car. Quote Link to comment Share on other sites More sharing options...
Indey Posted March 17, 2009 Author Share Posted March 17, 2009 Yes. Change the fluid and fix the shifter first. Search "Shifter Bushing" Check the control arm bushings, gland nut, anti-roll bar end links, wheel nuts, e-brake cable, rear brakes, insulator mount, and go buy a shop manual for the car. Thank you much sir, I actually got in contact with the old owner and yes it is a 4 speed manual, guess the shift knob was just lying to me =P. As soon as I get a chance to get the car over to my house I was going to pop it up in the air and just start checking things, so thanks for the tips on where to check, and the car came with a shop manual so I think I should be set to go =] Thanks again! Quote Link to comment Share on other sites More sharing options...
