Which gear ratio works best????
KG78Z
3.54, 3.36 is the best i think for high horse turbo, but rare. 3.7 is ok, but its the only way to get a lsd in there factory style so liveable.
3.90- you dont need that much gear back there, you will spool too fast and not be able to boost as much.
What trany are you working with??
I think that an 81-83 ZX 5 speed (originally fitted with a 3.9 rear) mated with a 3.7 LSD would be Ideal for a turbo given your tire dia. is around 25 inches......
Earlier trannys have higher ratios thus requiring the lower rear ratios.......
Thoughts anyone??
