Netural Safety Switch
Late Chevy trucks have the switch mounted on the side of the transmission... might not work with earlier 700R4s. Use a google search for LOKAR or RON FRANCIS WIRE WORKS or PAINLESS. The street rodders often use a oem switch bolted to the pan rails of the 700R4 to actuate a neutral switch. On the other hand, consider buying a cable operated aftermarket shifter.
gw
