ottoauto Posted April 1, 2009 Share Posted April 1, 2009 I just found a 2.8l engine that i want to swap into my car but my questions are. 1. i have a brandnew radiator with an electric fan. Will i have to swap this out for a 280z radiator or aluminum. 2. Which flywheel should i use? i have a brand new clutch on my 2.4l engine. Quote Link to comment Share on other sites More sharing options...
ezzzzzzz Posted April 1, 2009 Share Posted April 1, 2009 The rad you have should work fine, assuming it is two or three core, for a stock 2.8L. Use the flywheel and clutch assembly off the 2.4L. Be sure the pressure plate and throwout bearing are for the same application. 2.4L had a tall pressure plate and short bearing. 2.8L had a shorter pressure plate and taller bearing. Quote Link to comment Share on other sites More sharing options...
ottoauto Posted April 2, 2009 Author Share Posted April 2, 2009 thanks for the advice. I'm sure ill be able to use the info soon enough Quote Link to comment Share on other sites More sharing options...
