SU carbs out for tune...again
ASA240Z
hey guys,
i was wondering if anyone had any suggestions for keeping the SU carbs tuned.
This has been happening for the past couple years and I'm finally getting fed up with it. It seems that every time I tune my carbs they work well, no smell, no leaning out, etc. But I'm always having to retune them every couple weeks, otherwise they begin to run rich.
I was wondering is there was anything by loctite for example that would keep the adjustment screws etc in place, but not permanently.
thanks
ive never had problems with the su's getting out of tune...those screws should have a spring on them so they dont move..if its on there then its probably worn out...and it its not then you should get some...as for the mixture screw it should have a circle piece that screws on the bottom of the carb and keeps it from moving...hope this helps
