87 na2t on and off project of the past few
stprasinz
ok lets see where to start...
1987 300zx na 5 speed
turbo conversion
turbonetics 60-1 hybrid turbo
liquid intercooler
pathfinder intake
methanol injection
welded differential
electronic suspension
solid motor, tranny mounts
and a bit more......
pic with the modified hood, radiator vented to remove turbulence from under car, and raised approx 3.5" to clear the path finder intake;)
look at the pretty liquid heat exchanger:)
so what do you think?
I'm thinking about adding a few more touches, such as side vents?
I'm the only person who's done any of the work on any of my cars, and I kinda like it that way;)
soon to come mods, since I'm currently running stock junkyard motor
fidanza fly wheel
act clutch ( 4 puck, unsprung)
jwt valve springs
and obviously the cam, probably schnieder...
i got a megasquirt but figure the 300zx's main limitation is the afm, and since I don't think i need over 18 psi i don't see a need for aftermarket ecu and with the stock fuel curve, and methanol fuel should not be a problem... and since timing i'm told timing for the z31 after i believe 11 psi maintains 17 dbtdc so that shouldn't be an issue either....
