Lightening holes in crankshaft rod throws
PalmettoZ
I mean, it should be measurable on a wheel dyno if it makes a difference in the rate of acceleration.
Correct and a lightened flywheel will increase the rate of acceleration of a vehicle. The same as lighter wheels and tires. But it does not increase the horsepower an engine puts out - which is essentially a thermodynamic process.
Remember, a chassis dyno measures the ability of the engine and drive line to accelerate a mass and then a calculation is performed to determine horsepower. If you were to hold the engine/chassis at the max horsepower rpm on a chassis dyno (as you can on an engine dyno) there would be a statistically insignificant difference in horsepower resulting from the calculation with or without the lightened flywheel.
