WizardBlack Posted April 24, 2009 Share Posted April 24, 2009 IMHO, chain is better than belt. I've worked on more belts, though. If a chain is going bad, it with be stretched and your timing will be off a bit. You will notice. If a belt is degrading, it will either skip a tooth or break altogether. Much worse result. They both stretch. They both need replaced eventually. One needs oil and the other needs some cooling to keep it from degrading. Quote Link to comment Share on other sites More sharing options...
